Flateric
1.1.2 Repetier firmware, temp display.
Hello, just got my license code and I am having a few initial problems.
I am running a delta style printer and therefor my firmware of choice is repetier. It has a number of benefits over marlin for the delta crowd involving movement and accel/path enhancements.
While attempting to get all setup for my first print I am having issues with the temp being reported in the machine control window. The verbose log going past reports the temps correctly and I am able to control the print as per normal. The temp display graph also does not show anything at all. I have tried enabling the monitor box.
The same situation is present for both the heated bed and the extruder.
Fan control is functioning normally.
Simplify3D
Site Admin
Re: 1.1.2 Repetier firmware, temp display.
Can you make sure verbose mode it turned on and then copy and paste your communication log here? I should be able to help figure out what's going on based on the response that the firmware sends to the M105 temperature monitoring commands.
