Here is why it doesn't work for me. I'd love to get some suggestions for how I could make it work if it's working for others and not me.
1) I originally tried the object as is, support material in one extruder, plastic in the other.
* fail. After deprime/prime at tool change there isn't the right amount of plastic in the nozzle and it skips or blobs. You should be able to tune the retract right correct? You'd think so but when it sits for indefinite amounts of time depending on the amount of support material there isn't really a correct setting.
2) I added a skirt with layers 9999 and perimeters 3 for on the main extruder.
* fail, the nozzle always started at the same spot and eventually a buildup of plastic on the skirt caused the skirt to knock loose from the print bed.
3) I added an alternate object instead.
* fail, the order of objects can't be set so what would happen is it would print the layer on one object and switch tools and print the other then switch again so I got no benefit of using a dummy object as the priming object.
Anyway... in summary.. We're almost there guys.. Keep up the great work. Now just add the purge walls like everyone asked for months ago
