Hi 3d fellows!
I recently bought this amazing software for my Prusa I3 P3Steel, and I couldn't be happier.
Although, I have some questions about the software.
The first thing that I would like to discuss is about the first layer after the raft (when one uses it). So, if I define the raft, after the raft layers, I think that the really first layer of the print should also be slower than the others, correct? I'm asking this because if I set a fast print, and with a separation layer considerably large (lets say, 0,15mm for a 0,2mm layers), the first layer above the raft sometimes fails in some corners or holes, i.e., the plastic do not stick well enough to make a solid base to the rest of the printing, at the same time that the raft could be removed easily.
I know that if I reduce the separation gap, this problem can be reduced, but also the raft gets harder to remove.
Do you have some solution to this? I also tried to use multiple processes, but I didn't managed to do this.
Happy printings!
