Billzilla
Any plans to support Mingda and UP?
As per the title, just wondering.
mdlucca
Re: Any plans to support Mingda and UP?
I would like to know that as well. Bought a Mingda a few months ago and Simplify3d and I havent been able to print anything decent with it :(
The Mingda printer lists their software as being compatible with other open-source slicers, so I imagine it would also accept Simplify3D gcode.
The Up! will probably never be supported as it uses all proprietary stuff.
Billzilla
JoeJ wrote:The Mingda printer lists their software as being compatible with other open-source slicers, so I imagine it would also accept Simplify3D gcode.
Looks like that's the case, I emailed them about using Simplify3D and this was their reply -
"Yes, our 3D printer is also compatible with G-code, so you can use the simplify3D software to help with your work. (Normally, we use CURA software for slicing)"
Interesting .....
edvardrahelic
hI
Good profile for Mingda Glitar 6c,,,For different model only change printing volume( Hight of print ) ,,If you need firmware,display drivers or Win drivers be free to ask,,
Mingd G6.fff
profile for Mingda 6
(9.05 KiB) Downloaded 547 times
edvardrahelic
settings
TeeGeeRoo
@edvardrahelic - Do you still have software for the Glitar 6c (firmware, drivers)? Thx :)
