jrpmedia
Re-Import in-Place
regarding this Post: http://forum.simplify3d.com/viewtopic.php?f=8&t=1160
The INTIAL idea in this POST (link above) really is an issue for lots of production work IMO.
It takes me a long time to place and re-arrange all the objects on the Bed manually.
If I need to remodel (very slightly) one of these objects and replace it (or say 2 or 3 out of 8 objects) then it's a real ball-ache to reposition .. eventually the whole set screws up, even if it is due to Human error on my part #tiredsometimes.
Can there not be a way to replace objects, or reload them from the .s3d folder/file format/zip?
Adobe Illustrator does this very well with 'linking'.
It asks you if you want to update modified files when you open the file ... #excellent
IDM Imagineering
Professional Equipment for SuperHEROs.
https://www.idmimagineering.co.uk
AK_Eric
Re: Re-Import in-Place
+1 for this: Would make updating with new revisions way easier.
Bots:
Makerbot Replicator 2x / Sailfish on Mightyboard
Custom C-Bot / RepRap Firmware on RADDS
Custom Tevo Little Monster / RepRap Firmware on Duet
jrpmedia
Is this near the TOP of the list ? :-) √√
IDM Imagineering
bot
Definitely a useful feature. :mrgreen:
Yona.Appletree
+1 for this. Especially when using custom supports, this would be a HUGE time saver for small adjustments.
@Yona - if it is just the supports that you are worried about, you can always export the support structures using the custom support dialog. Then re-import the new model and import the support structures back in. That way you don't have to redo any manual changes you made to the support structures.
aricnorine
+1
Trax
+1
AtefAzaiez
Definitely a time saver +1
