Hello!
I am new to Simplify3D, so I am still learning as I go. I have a model I am trying to print that I designed in Fusion 360, and it seems I am having some problems accurately printing it when exporting it to Simplify3D.
There is a slot in it, about 8.1" x .45" and every time I print using Simplify3D, the slot ends up being .03 or more off with the short dimension. Long dimension is short too.
Here is the strange part... using Makerbot Desktop, I was still off, but I was closer to the size it should be. Long dimension was fine, but short was off by about .01"-.02".
The object stretches my machine to the limit... the bed is 8.8" roughly and what I am printing comes out to be about 8.5". First time I printed, I left the skirt on not realizing it wouldn't error or anything.. it printed, but it automatically scaled it. I am wondering if that is still happening even though I disabled the skirt, but I have no way to verify this since I can't seem to find a way to get dimensions other than what it says the object dimensions are in the model (which, when converted from mm to inch, are spot on).
Is there a way to determine if it is still scaling the model down, or is there a way to prevent it from doing so? I don't think the printer is the issue.. I printed other items that fit well on my bed and they appear to be just fine (printer is a Wanhao Duplicator 4, I printed mounts for side plexiglass and they printed just fine, sliced with Simplify3D).
Just not sure where to start with this problem. I am printing a size gauge right now.. varying slots in the 8"x.45" range to see how much things change, and if it still does not come out right, I'll print with Makerbot Desktop to see if there is a difference, but hoping someone knows some secret setting in Simplify3D that I am missing.
I have attached the factory file for the gauge (which I am still trying to figure out... it seems to keep opening the same factory file over and over, it would be nice if the processes could be saved but it opened a new factory file every time.. maybe I am just not used to the workflow yet).
Thanks!
