Trying to print an assembly with two objects = dual printing with different materials.
Assembly is created with two parts in correct relative position.
When placing the different objects on the plate, I need to move and rotate them (around x- or y-axis) to another position but the software only allows for moving and rotating in the x-y-plane, not rotating around x- or y-axis.
I can only rotate one object at a time. This messes up things because then the relative position of the two objects are lost and they cannot be printed.
How do I rotate two objects at the same time (for example 90 degrees around x-axis) keeping their relative orientation?
