I've noticed that after importing a model and then modifying its transforms under the "model settings" panel, the amount you have altered from the original transforms are retained even when you close and re-open that dialog. This is super useful because it allows you to check the changes you have made as well as match scale between different models. However when you save and reload a factory file this information seems to be lost and the new transform matrix is seen in the model settings panel as 0,0,0 pos/rot and 1.0 scale factor.
Is there any way to force this to be retained so you can always see how much you have moved, rotated and scaled your object vs the original imported model? Being able to always see the SCALE factor is really important for getting parts to match.
Thanks,
M
