I'm currently using Cura with a MakerFarm 12" i3V Prusa. The way that the MF setup auto home has the X axis end stop on the right side of the machine when you are facing it.
This is opposite of what Cura is expecting so if I put a model in Cura it prints mirrored in the wrong way. I have to do a X axis mirror in Cura to make the text right.
There is a physical modification that I can do to the printer to make it right in Cura, but I was wondering does S3D have a setting where you can permanently setup the printer so that I wouldn't have to do that mirroring? If that was possible, it would be really great and I am a new customer, if not, I need to research this purchase a bit more.
Thanks
Cameron
