mitchfx
[ADDED] Update of Dimensions When Changing Scale Values
Is there any way to have the calculated object dimensions in mm update in response to changes in the Scale value without the need to keep closing and re-opening the model settings dialog? It would also be extremely useful to be able to type a desired target mm into one of the three XYZ bounding box dimensions and have the scale update accordingly to the appropriate value.
Same goes for position offset vs calculated coordinates.
mitchfx
Re: Dynamic Update of Dimensions When Changing Scale Values
After a few more hours setting up prints I can honestly say that having the dimensions update dynamically when a new scale is typed in would be my #1 feature request. It's a drag to adjust scale, close the dialog, reopen, check new dimensions, then repeat until my desired size has been achieved. This would take much less time if I could simply see the new dimensions value immediately after adjusting scale value.
Thanks,
M
This feature was added in version 3.0. When changing any of the model parameters like position, scaling, or rotation, the dimensions will automatically update.
