madeinoz
BUG: Support layers stopping 1 layer multi processes
Hi Guys,
When using more than 1 process I'm finding that the support layer is stopping 1 layer short of the top of the current process, this is causing problems with the next process.
using version 2.2.2 OS X
See screen shot of where two processes begin/end
madeinoz
Re: BUG: Support layers stopping 1 layer multi processes
Here is factory file incase I'm doing something completely wrong
RoofRack.factory
(284.51 KiB) Downloaded 320 times
SockMonkey
madeinoz wrote:Here is factory file incase I'm doing something completely wrong
If I'm looking at this correctly, the Top/Bottom Nylon processes are for the support material (second extruder) and the process, "Process 1" is for the model, right? I turned off support generation on the Process 1
In the "Bottom Nylon" process, in the support tab, set the Upper Vertical Separation Layers to 0, and in the "Top Nylon" process, set the Bottom Vertical Separation Layers in the support tab to 0.
madeinoz
Not the two processors were for the same extruder, I wanted to speed things up on the solid layers. So just one extruder for support and model, both nylon.
palawanisland
might be :
check edit process setting -> support tab -> seperation from part group -> upper / lower vertical separation..
madeinoz
palawanisland wrote:might be :
Thanks for that will test the setting
