I have a Leapfrog Creatr dual. The other day all motors suddenly stopped moving during a print, although there was no error message and the print completed.
I discovered a fried diode on the bottom of the electronics board in the power path that feeds all the stepper motor drivers. I replaced the diode and the motors now respond normally to manual jog control.
But the printed won't work normally using S3D (athough it does work using Repetier!).
At first I thought the printer simply locked up when I start a print, but then noticed that the motors actually move and the print progresses VERRRRY slowly, almost imperceptibly. Seems like the stepper motors move at about 1 step per second!
Again, it does work normally using Repetier!
Anyone have a suggestion of what the issue is?
-Matt
(PS: I have reflashed the board a few times, and re-installed S3D twice.
I also replaced the MEGA2560 chip with no change in behavior.)
