sarge5020
Why does this happen?
Any ideas why this happens? I'm printed this in ABS at 230 degrees C with a bed temperature of 110 degrees C sliced at .1mm.
sarge5020
Re: Why does this happen?
I had similar results printing with Bronzefil. Here are the two models http://www.thingiverse.com/thing:738561 and http://www.thingiverse.com/thing:715111 Maybe someone can have a look and see if there is some issue with the models. I run them through Netfabb before printing.
Cheers,
John
DarthRevan
Could you attach your factory file so I can look at what might be causing this?
sarge5020
Forgive me but how do I do that?
bot
My guess is one of or a combination of two things:
1) too small layer height relative to nozzle size.
2) too low resolution on your extruder stepper driver axis.
DarthRevan
sarge5020 wrote:Forgive me but how do I do that?
sarge5020
Thanks. here is the factory file for a model printed with Bronzefil with the same results. I'll post a photo of those prints a little later.
ISAF John.factory
(1.11 MiB) Downloaded 449 times
sarge5020
Here is the model printed in bronzefil. Different material, same results.
DarthRevan
You should be fine with those settings. Perhaps your machine needs to be recalibrated. As bronzefill is one of the pricier materials I'd try printing some calibration prints in PLA. You definitely want the settings perfect when using <= .1mm layer height, as the margin for errors is much more noticeable the more detail you aim to have.
sarge5020
Would you suggest .2mm layers?
