Re: Bug in temperature adjustments with hot bed
Posted: Mon Feb 16, 2015 8:19 am
by monachus
It seems that setting the same temp for the toolhead no longer works. The gcode file doesn't contain the line, even if the toolhead is listed after the HBP. It will work, however, if I set the temp to 201 at layer 5 and then back to 200 at layer 6.
Posted: Sun Feb 22, 2015 4:22 pm
by jmsjgill
I'm experiencing this bug, too. Has anyone submitted a bug report? Since we're paying for this software, I'd hope S3D would at least address this.
-Jason
Posted: Mon Feb 23, 2015 5:41 am
by JoeJ
There's plenty of ways to fix this. Read this:
http://forum.simplify3d.com/viewtopic.p ... 124&p=8613
You can just change the "set bed temperature" command in your firmware configuration to be "M140 S#" (just remove the T0 part). Done! Solved.
The developers are also aware of this, but unfortunately, it's actually an issue with the GPX convertor, not the Simplify3D code. From what they have told me, they are working to patch GPX to resolve it for everyone.
