Page 2 of 2
Re: Default supports are flawed
Posted: Fri Jun 13, 2014 7:24 pm
by dennisjm
I reset the extra distance and separation parameters and tried again before resetting the max angle. The max angle doesn't affect it much, it's the first two parameters. I had already tweaked those before I sent you the factory file which is why it worked for you already.
Posted: Fri Jun 13, 2014 9:21 pm
by jimc
i tried it as well and everything worked great. the 1mm grid is a bit excessive. i put it back to 3mm with a 45deg angle and a .3mm vert separation. any closer than .3 and it can bond to the model making it hard to remove. these settings are very close to where i run mine and i never have a support issue. it always does what it says its going to do.
Posted: Fri Jun 13, 2014 11:55 pm
by dennisjm
Except Jimc look closely in your screenshot.. the middle of the wing where it sticks down has no support under it. That's the issue I was addressing.
