Re: Feature Request - Lay Flat
Posted: Sun Sep 21, 2014 5:07 pm
+1
Would be a time saver. I get file that must of come from another planet sometimes.
In the Model Menu along the top of the programGotham Pixel wrote:In the Unofficial Simplify3D Documentation http://jinschoi.github.io/simplify3d-docs/
they write:
"Position your models
Models appear at your bed origin, usually set to be the lower left corner of the bed (this is configurable under Preferences/Machine). Use the Arrange button to auto-arrange them near the center, or manually place them using the preview window or edit dialogs. If you do manually move your models, make sure to use the Drop button so none of them are hovering over the bed."
where is the "Drop Button"
Are you CAD'ing the models yourself? It seems weird that all your models would need to be "laid flat" in angles that aren't in increments of 45, i.e. easy to manipulate angles.laird wrote:I've been using Cura to level prints, then S3D to print. Seems inefficient.
No, when I model things they're oriented to print, because I am designing them for printing. But often people send me files to print, or I download them from Thingiverse, etc., and then orientation can be a challenge. For example, if a design is oriented in a way that makes sense for viewing, it may need to be rotated to be best oriented for printing. And scans are almost ever printing at the orientation generated by the scanner.habloIngles wrote:Are you CAD'ing the models yourself? It seems weird that all your models would need to be "laid flat" in angles that aren't in increments of 45, i.e. easy to manipulate angles.laird wrote:I've been using Cura to level prints, then S3D to print. Seems inefficient.
