Page 2 of 2
Re: Bug in 4.1 with first layer of print
Posted: Fri Dec 28, 2018 7:02 pm
by tambeb
ATTN: eldany
Hit me up at my username at gmail, or message me here.
Posted: Sat Jan 23, 2021 4:10 am
by JWThijsse
For me the same, printing is impossible on first layer extruder prints oneway.
So gaps are between lines
Is this issue gonna be fixed within a reasonable time.
When I print with Prusaslicer I have no problem.
I have a Prusa i3 mk3s, with Bondtech upgrade.
Certain files prints diagonal instead of straight lines
Posted: Sun Jan 24, 2021 7:23 am
by rjmusto
Using S3D 4.1.2
Not sure if this is connected, but I now have a problem where a splurge of filament is deposited at the start of each layer.
Is this also a bug in this version?
Thanks.
Posted: Mon Jan 25, 2021 11:16 am
by rjmusto
Here's a photo of a print I stopped after the first couple of layers. You can see the 'blobs' deposited when a new layer starts - the extruder gives a short forward burst.
I have tried printing files done some weeks ago and they are fine. It is only the new ones I produce that are showing this.
Any ideas?
Posted: Mon Jan 25, 2021 12:19 pm
by rjmusto
Looking at the gcode file, here's an extract from the start of the file:
G92 E0.0000
G1 E-1.2000 F900
; feature skirt
; tool H0.300 W0.360
G1 Z0.800 F1000
G1 X81.420 Y95.820 F4800
G1 E5.0000 F900
G92 E0.0000
So does the G1 E5.0000 not mean 'extrude 5mm of filament'? In which case, what is going on? I don't see this line in older files.
Posted: Tue Jan 26, 2021 12:51 pm
by rjmusto
Sorted.
The 'Extra Restart Distance' on the Extruder tab was set to 5.0. Have never even considered this parameter before, so no idea how that got changed.
All a bit odd......
