Re: No extrusion K8400 in V4.1.1
DKHDKH wrote: ↑Wed Jan 02, 2019 1:10 pm
Harry_D wrote: ↑Mon Dec 31, 2018 9:05 am Not sure why having an alternate first layer height would stop extrusion, though... seems unrelated? Are you creating new printer profiles for the printer in the 4.1.1. version of S3D? If so, try using your 4.0.1 profile in 4.1.1....?
The 4.0.1 profile does not work with version 4.1.1. I created a new file and then found out that the Primary Layer Height or First Layer Height gives the extrusion problem.
I hope that something can be done quickly because I have nothing on this version.
I gave a solution here: viewtopic.php?f=9&t=6876#p46986. There should be no issues with changing the height positively. If you're trying to lower gap between bed and nozzle, please use the G-Code tab's Global G-Code offsets for the Z axis.
