Re: Question about auto mode nozzle width
Posted: Wed Jul 02, 2014 1:39 pm
RichWebb, the effect you refer to is die swell and it varies with material and extrusion speed. But you don't have to lie to the slicer about anything nor should you need to change flow rate multiplier when changing extrusion width. Extrusion width is the width of each thread laid down.
If you cut a print in half vertically and look at a single cross section of filament, it would have a height equal to your layer height and a width equal to your extrusion width. That's called the extrusion profile. The width should be at least 1.5 times the layer height and greater than the nozzle diameter to ensure that the filament is sufficiently squished to the layer below. If your extruder steps / flow rate multiplier and filament diameter are calibrated well then the correct volume of plastic should be delivered to match your desired extrusion profile, no matter what width / layer height combination you choose. I frequently print extrusion width as high as 0.75 mm on a 0.4 mm nozzle and always have very smooth surfaces. If you have to set the extrusion width as low as 0.4 on a 0.4 mm nozzle to get a smooth top surface, then your flow rate is too high and you need to recalibrate e-steps or measure the filament diameter again because the printer is delivering more plastic than the slicer expected. Lowering the extrusion width helps a bit because it reduces overall flow rate (flow rate = layer height * extrusion width * print speed) but it's just masking the problem of over extrusion.
Dennis, this is why I don't think that extrusion width is the solution to your support material challenge - circumstantial as you say. But you are correct, the tool path will change accordingly to pack thinner or thicker lines, and yes, increasing the extrusion width to 0.6 will cause more plastic to come out. A 0.4 mm wall gets ignored by the slicer if you set extrusion width to 0.4 mm or higher because it can't meet your demands. It's like trying to build a 1/4" wall with 1/2" plywood. 0.39 mm filament works because it's narrower than the wall but keep in mind that layer bonding will suffer as the extrusion width approaches the nozzle diameter. This is why I am somewhat disappointed that auto width doesn't do much of anything - the slicer could be smart enough to detect a 0.4 mm wall and reduce the extrusion width to accommodate. It detects bridges and other features, why not thin walls?
One other thing to note is that a perfectly calibrated extruder will print a 0.4 mm wall closer to 0.45 mm because the filament bulges a little bit at the sides. As far as I can tell, S3D, like all the other slicers, assumes that the extruded filament is square, which is incorrect. See the following links for a more detailed explanation of this.
http://hydraraptor.blogspot.co.uk/2011/ ... -rate.html
http://hydraraptor.blogspot.ca/2014/06/ ... wrong.html
