Page 2 of 2
Re: First layer Extrusion multiplier
Posted: Fri Mar 11, 2022 4:59 am
by parallyze
dibor wrote: Thu Mar 10, 2022 5:45 pm U can use this settings instead
U will get same effect.
Nope.
Using a first layer height below 100% will now correctly reduce the amount of extruded material (alternatively, a negative global Z-axis offset can be used to lower the first layer while still extruding the same amount of material)
https://www.simplify3d.com/software/release-notes/
This change was introduced in v4.1.0, so you can't simply lower the 1st layer height to get more squish as in previous versions.
