Re: Scars/Scuffs on surface of prints?
Posted: Thu Sep 24, 2020 6:03 pm
Okay, @parallyze, maybe you can help me with something else, something smaller?parallyze wrote: ↑Sat Sep 19, 2020 9:54 pmI didn't notice you were using seperate processes _AND_ separate gcode files. Most people just do a color change and resume printing usingJustMKollum wrote: ↑Sat Sep 19, 2020 8:17 pm Remember, this GCODE is only part 1 of 2. I split the model into 2. I should have provided the 2nd part for less confusion. In fact, here you go.
http://www.mediafire.com/file/9m16sybab ... gcode/file
The 2nd part is colored black that you see in the pictures, and it's a 2nd GCODE or 2nd process. That keyhole you see eventually gets sealed at the top, so that's what require's support, so the top doesn't cave in.
a single gcode file, as far as I can tell... so you're printing the first (purple) gcode file, then swap filaments and then start the second (black) one? The second one does include homing all axes..?
(And the first one ends at 4.18mm height, the second one does start at 4.5mm using 0.2 layer height, 1st layer @90%...is that gap on purpose?)
Keyhole: With that many solid layers on top I'm pretty sure this should work without supports (and maybe 1 layer of bridging).
Anyways, all the tiny spots all around at layer 18+ (first gcode file) have nothing to adhere to and will get dragged all over the surface (there's 30-40 of them on the in- and outside).
And looking at it... I actually don't understand how you expect this to be a nice print. The black part is much bigger than the purple one:
There's absolutely nothing supporting the black part all around...?! You should definitely check your support generation settings.... ^^
I uploaded the .Factory file for it instead of the GCODE to make things easier:
http://www.mediafire.com/file/waxhsb3op ... ctory/file
It's similar to what I was printing before with the separate processes. This time the first process will be matte yellow and 2nd process will be matte black.
This print shouldn't require supports, at all.
I'm still having surface scratching issues, and I hope the .FACTORY file will help. Please let me know if there's anything I need to change.
Thanks!
