Page 2 of 3
Re: Cannot Activate New S3D Lisence
Posted: Sat Dec 18, 2021 1:53 pm
by cityshaker
I'm also having the same problem today.
Posted: Sat Dec 18, 2021 5:31 pm
by Billzilla
waynejacobsen wrote: ↑Fri Dec 17, 2021 11:52 am Any workaround or fixes?
Get Prusaslicer or Cura.
Problem solved.
Posted: Thu Jan 20, 2022 6:12 pm
by truegret
Same issue
Uanble to connect to the activation server.
Please ensure that you have an active
internet connection prior to activating.
I removed one of the assigned licenses to the MacOS machine (connected to my printer), uninstalled, reinstalled Simplify3d-4.1.2, error continues. Contacted support. No response.
Posted: Wed Jan 26, 2022 5:49 pm
by TMK112
same error messages as all, just paid and tried to use software activation server not allowing, says I don't have Internet connection, but I'm using same internet to post this exact message, did I just waste 150?
Posted: Sat Jan 29, 2022 12:36 am
by cnd
The issue on my Mac turned out to be an old certificate bundle file. Here's the "history" of steps I took that fixed it for me:
115114  Jan 27 09:46:15  cnd@/Users/cnd/cd/Downloads/un  curl -k -L -O 'https://curl.se/download/curl-7.81.0.tar.gz'
115116  Jan 27 09:46:30  cnd@/Users/cnd/cd/Downloads/un  mkdir c
115117  Jan 27 09:46:31  cnd@/Users/cnd/cd/Downloads/un/c  cd c
115118  Jan 27 09:46:36  cnd@/Users/cnd/cd/Downloads/un/c  tar xvfz ../curl-7.81.0.tar.gz
115119  Jan 27 09:46:56  cnd@/Users/cnd/cd/Downloads/un/c/curl-7.81.0/lib  cd curl-7.81.0/lib
115122  Jan 27 09:46:59  cnd@/Users/cnd/cd/Downloads/un/c/curl-7.81.0/lib  ./mk-ca-bundle.pl
115130  Jan 27 09:48:33  cnd@/Users/cnd/cd/Downloads/un/c/curl-7.81.0/lib  cp ca-bundle.crt ~/Downloads
115151  Jan 27 09:52:19  cnd@/etc/ssl  cd /etc/ssl/certs
115155  Jan 27 09:52:35  cnd@/etc/ssl/certs  sudo cp -a ~/Downloads/ca-bundle.crt .
115157  Jan 27 09:52:39  cnd@/etc/ssl  cd ..
115160  Jan 27 09:52:50  cnd@/etc/ssl  sudo mv cert.pem certo.pem
115161  Jan 27 09:53:02  cnd@/etc/ssl  sudo cp -a certs/ca-bundle.crt  cert.pem
Posted: Sun Mar 06, 2022 3:26 pm
by Reckerke
It was tough to follow your instructions not being that great with the CMD prompt but I muddled my way through this and it worked for me after updating to 4.1.2. I ran into problems at the following step:
Receiving the following error:
cp: ~Downloads/ca-bundle.crt: No such file or directory
Ultimately I pushed through and manually typed the directory in full after searching it out in Finder and it worked like a charm. About 45 minutes of learning to use the command prompt and 2 hours of reading the forums and I am back online after updating the program.
:D CND's Solution (although not quite as cut and paste for me as I would have liked) is verified as of 06 March 2022! :D
MAC OS Mojave 10.14.6
Thanks!
Posted: Fri Mar 18, 2022 2:47 pm
by aerodan
This post should be stickied. It literally saved my project from being late! Thank you thank you!
AD
cnd wrote: ↑Sat Jan 29, 2022 12:36 am The issue on my Mac turned out to be an old certificate bundle file. Here's the "history" of steps I took that fixed it for me:
Posted: Sun Mar 20, 2022 6:24 pm
by ajinop
do you have any additional info, my terminal skills are rather weak?
Posted: Thu Mar 24, 2022 11:30 am
by S3D-Jake
ajinop wrote: ↑Sun Mar 20, 2022 6:24 pm do you have any additional info, my terminal skills are rather weak?
Contact support. They can walk you through it.
Posted: Sun Nov 27, 2022 4:22 pm
by cityshaker
Having this problem again. Support are you listening? What can I do?
