Page 2 of 2
Re: No longer able to drag models using (any) key on MacOS!!
Posted: Fri Jan 13, 2023 11:51 am
by S3D-Jason
anthonype wrote: ↑Thu Jan 12, 2023 10:51 pm Unless you change your Mac trackpad settings to set right click in the bottom right corner (I have mine set up as a double finger tap), then you will be unable to pan.
I just click anywhere on the trackpad using 2 fingers and then panning works fine. I believe most Mac trackpads already right-click by default when you press with 2 finger, so you shouldn't need to change any settings.
Posted: Wed May 15, 2024 7:10 pm
by anthonype
S3D-Jason wrote: ↑Thu Jan 05, 2023 6:21 am You can just right-click on the trackpad and drag to pan. I just tested it on a Mac laptop here and it seems to work fine.
I have been having issues with this as well. Unless you change your Mac trackpad settings to set right click in the bottom right corner (I have mine set up as a double finger tap), then you will be unable to pan. On V4 I used the CMD key + left click to pan. V5 is practically unusable for myself without a mouse unfortunately. I personally prefer my settings to be a 2 finger tap for right click and just couldn't adjust to the rest of my day to day with that setting changed just for Simplify3D V5.
I really hope we get some more options. I know it's a tiny issue but it's definitely one that makes the usability factor on V5 very frustrating. At first I actually though this feature was removed...
Definitely looking for this as well. My situation and explanation is 100% a match to yours. It's just too unusable for me on Mac anymore. Should be a basic setting to re-implement considering it worked in V4
Posted: Thu May 16, 2024 12:49 pm
by S3D-Jason
I have a Mac laptop sitting right next to me. Click and drag with 2 fingers to pan works fine with S3D V5. Same for pinch to zoom. Rotate is just a single mouse click. That's the same way 3 other apps on this computer work for navigating the 3D view, so I think it's reasonably intuitive.
