Page 2 of 3
Re: v5.xx slicing Issues. Madness continues!!
Posted: Fri Feb 03, 2023 1:04 am
by bolsoncerrado
My suggestion is you update the software and fix those damn bugs. I'll attach the file in a couple hours. :(
Posted: Mon Feb 06, 2023 7:50 am
by bolsoncerrado
Here's the "offending" file...
Posted: Mon Feb 06, 2023 8:21 am
by parallyze
bolsoncerrado wrote: ↑Mon Feb 06, 2023 7:50 am Here's the "offending" file...
Hmm... 2 shells with 0 distance? This looks like something they've introduced with 4.1.1...
Got this from support on May, 24th 2019:
"We've documented this so that we can track the behavior with models imported with coplanar surfaces. As this is not technically a valid mesh, it's behavior is usually not considered, since the slicing engine expects a valid mesh. I would strongly recommend taking steps to make sure that your models are a single, manifold model on exporting from your CAM software. "
I sometimes imported assemblies from CAD with seperate bodies touching each other (not intersecting), starting from 4.1.1 the models had to be merged into a single body.
But to be fair here - it is tricky. PS doesn't handle this completely flawless in all cases:
It does slice in your case because you likely have the default setting for slicing gap radius set
to something > 0.
Using defaults does work:
...but only because PS is now completely ignoring the "zero space" gap between your parts where two parts end.
I often include very tiny cuts to geometry to speed things up/use vase mode, without reducing the slicing
gap radius (same for Cura) those slicers will handle a flawless file wrong and increase print times immensely.
As always, depends on what you need and how clean your model files are.
Posted: Mon Feb 06, 2023 8:39 am
by KOPrinting
Under the advanced tab, try changing the Slicing Region Repair mode to Merge all Boundaries.
Posted: Mon Feb 06, 2023 9:14 am
by parallyze
kaween wrote: ↑Tue Jan 31, 2023 6:43 am STL is flawless (manifold, zero errors according to our Materialise Magics software - same info is given by Ideamaker, Netfabb, Microsoft's various 3D tools and _even_ S3D_ can't find anything wrong withe the stl)
A flawless STL file including multiple volumes should be splittable as well. Tried it on bolsoncerrado's STL, no matter
which program - they all fail seperating the two shells again. Blender, MeshMixer, S3D, PS, ideaMaker...
I'd check that file, quite quirky behavior for such a simple geometry.
Posted: Mon Feb 06, 2023 7:31 pm
by DrD
Using the provided STL, It does slice correctly.
The key is to change the following setting in the "Advanced" tab.
Not intuitive, I know. It's a setting that most of us don't use very often.
D.
Posted: Mon Feb 06, 2023 7:47 pm
by parallyze
DrD wrote: ↑Mon Feb 06, 2023 7:31 pm Using the provided STL, It does slice correctly.
That's not really what he wants. He wants it to be printed with the outer shell only, like he's
shown in PS:
The halves merged inside the STL aren't merged properly, that's what's causing these troubles.
If what he has shown in PS is what he wants the "2 shells" indicator should've already raised
an eyebrow.
Posted: Mon Feb 06, 2023 8:33 pm
by billyd
I've attached a corrected version of the stl that will slice on anything.
Posted: Mon Feb 06, 2023 8:45 pm
by DrD
parallyze wrote: ↑Mon Feb 06, 2023 7:47 pm
shown in PS:
an eyebrow.
Ah, gotcha. Thanks for pointing that out.
D.
by KOPrinting
shown in PS:
I can't get this model to print that way in V 4 as well. Curious what his settings in V4 are that allow him to do that.
