Page 2 of 7
Re: Show your printings done with Simplify3d
Posted: Wed Mar 04, 2015 1:47 pm
by mitchfx
Latest print from last night - THEY LIVE!
another angle
another angle
Zbrush sculpt of the 121 yr old Dustin Hoffman from "Little Big Man"
Posted: Wed Mar 04, 2015 1:57 pm
by mitchfx
assorted heads and busts
~2" test print of The Thing (prototype for larger multi-piece print)
3" zbrush portrait of makeup FX man Steve Johnson
Posted: Wed Mar 04, 2015 6:18 pm
by dennisjm
Here is a good example of S3Ds latest horizontal size compensation feature. I took -.15mm off the ring part on this to make the threads perfectly fit together. Threads like it was tap and died.
Posted: Fri Mar 06, 2015 6:45 pm
by CT4
Printed this cross sectioned jet from a file on thingiverse. printer was a modified Makerbot Rep 2
Clean print with minimal cleanup. I added a bit of weathering to make it look used.
Posted: Tue Mar 10, 2015 4:51 pm
Rather than showing images here, i can give a link to what I'm currently using S3D to slice & print for:
http://www.talkingtgauge.net/viewtopic.php?f=8&t=123
http://www.talkingtgauge.net/viewtopic.php?f=11&t=76
I used ReplicatorG for the earlier prints, but moved to S3D last November.
btw Looking at the photos in the second link, you need to be aware the gauge of the track is 3mm.
Posted: Thu Mar 12, 2015 9:40 am
by Bubolz
Hi!
Here is a project that was only made possible through to the 3D Simplify!
I believe this is the first metal detector with structure 100% printed in 3D ever created. Recently came out an article about it on the site 3DPI:
http://3dprintingindustry.com/2015/01/2 ... -detector/
The detector was fully printed in ABS on a Cartesian cubic printer designed and built by myself and I baptized of Protobot.
To produce the threaded rods I used three different processes, there are threads in the top and bottom of the piece, I used 0.15 layer height in the region of the threads and 0.28 to print the central body to increase the speed printing.
I tried to position the other parts so as to avoid the use of supports.
The hardest part of making was precisely the coil, because of the difficulty to printing large pieces in abs due to the problem of WARP.
I made the impression in two stages, it was necessary to introduce a break in the g-code so I could stop printing to insert the copper coil inside and then resume printing hermetically enclosing the coil.
Abs.
Paulo Bubolz
Test on the beach
Objects found in the first test
My Protobot 3DPrinter
Screw and nut for fixing the coil
One of the four rods printed
Handle printed without supports
Base of the box
Top of the box printed without supports
Base of the box with electronic
Mounted box
Box mounted with stem
Printed coil
Coil mounted
Complete assembly
Posted: Fri Mar 13, 2015 10:16 am
by dunginhawk
that is amazing... are you making the plans available? either free or for sale?
thanks
Posted: Mon Mar 16, 2015 8:02 am
by Bubolz
Hello Dunginhawk! Until now i no have plans to make available or to sell the files... but I do not exclude this possibility in the near future. I'm working on a new smaller and lighter version.
Abs.
Paulo Bubolz
Posted: Thu Mar 19, 2015 8:31 pm
by BorisC
This is ABS, Simplify3D, 235c degree, 0.15mm, 7h25mins, 163mm tall.
Simplify3D provides most easiest supports removal. Can't believe it's so cool.
Posted: Fri Apr 03, 2015 7:32 pm
by JMP
Showed this off at the Midwest RepRap Festival. Several people commented on the quality of the print.
