Page 2 of 2
Re: 200% infill goobers
Posted: Fri Mar 06, 2015 9:48 am
by JFettig
ESUN
This part turned out real nice except for one burnt chunk right in the middle.
250C nozzle
75C bed(PEI)
35mm/s
wiping on everything
6mm retract.
Posted: Fri Mar 06, 2015 10:19 am
by jimc
The esun is good stuff. I have burnt through about 6 spools in the past month. Definately crank down your infill width. 200 caused me problems. The sweet spot for that stuff for me like i said is 140-150. I can give you my profile for it but i see you have 6mm if retract so you must have a bowden extruder. Indoubt my profile would help. I run a direct drive e3d.
Posted: Sat Mar 07, 2015 12:17 am
by JFettig
I have it pretty well dialed in. Temperature is very dependent on speed, around 35mm/s I can get away with 250, I have to bump it up to 260 to run 50+mm/s
150% infill width did the trick, also getting it to wipe at the end of the infill was also necessary, or prevent it from needing to retract before it goes to the next border.
