Page 2 of 3
Re: WARNING: CRC mismatch detected
Posted: Sat Sep 26, 2015 2:38 pm
by DonSch
Getting the same errors after upgrade to Windows 10. It seems to work until the monitor goes to sleep even though all other power saving settings are off.
Posted: Sun Sep 27, 2015 8:41 pm
by DonSch
I just wanted to follow up that after downloading updated chipset drivers from Dell, this particular problem went away. And if you are reading this and jumped from Windows 7 to Windows 10 like I did, I read elsewhere that if Windows 10 drivers are not available for your computer, it is very likely that the Windows 8.1 drivers would work as well.
Happy Printing!
Posted: Fri Apr 15, 2016 8:57 pm
by Gasmart81
Hello, i wonder if you resolve this issue. I upgrade to windows 10 and everything worked well at the beginning, but after a month suddenly the CRC mismatch error appears.
Thanks,
Gaston.
Posted: Thu Jul 13, 2017 5:05 pm
by Blaxius
I faced the same issue. Please reset the coordinates (ZERO) on the top right corner of the Machine Control Panel. Then Simplify3D connects by itself.
Posted: Fri Oct 27, 2017 9:16 pm
by wendelswartz
I am running a Tronxy X5S and get this from Simplify every time I try to connect from my Windows 7 pro 64 bit laptop.
Someon e please give me a clue as to what is going on here...
Attempting connection at \\.\COM3...
READ: XLAOD
READ: echo: External Reset
READ: Marlin 1.1.6 dev
READ: echo: Last Updated: Aug 30 2017 17:45:48 | Author: (none, default config)
READ: Compiled: Aug 30 2017
READ: echo: Free Memory: 11427 PlannerBufferBytes: 1232
READ: echo:Hardcoded Default Settings Loaded
READ: echo:Steps per unit:
READ: echo: M92 X80.00 Y80.00 Z400.00 E90.00
READ: echo:Maximum feedrates (mm/s):
READ: echo: M203 X400.00 Y400.00 Z4.00 E50.00
READ: echo:Maximum Acceleration (mm/s2):
READ: echo: M201 X1000 Y1000 Z1000 E1000
READ: echo:Accelerations: P=printing, R=retract and T=travel
READ: echo: M204 P1000.00 R1000.00 T1000.00
READ: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
READ: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
READ: echo:Home offset (mm):
READ: echo: M206 X0.00 Y0.00 Z0.00
READ: echo:Material heatup parameters:
READ: echo: M145 M0 H180 B40 F0
READ: echo: M145 M1 H240 B70 F0
READ: echo:PID settings:
READ: echo: M301 P22.20 I1.08 D114.00 C1.00
READ: echo:Filament settings: Disabled
Testing plaintext communication protocol...
Testing binary communication protocol...
READ: echo:SD init fail
READ: ok
Testing alternate communication protocols...
READ:
Connection failed.
Posted: Sat Oct 28, 2017 11:16 am
by brian442
wendelswartz wrote:I am running a Tronxy X5S and get this from Simplify every time I try to connect from my Windows 7 pro 64 bit laptop.
Looks like you're printer is taking a while to respond. Try following the suggestions at the link below. In particular, disable the "wait for startup command" option.
https://www.simplify3d.com/support/faq/#faq-4630
Posted: Tue Jan 09, 2018 4:25 pm
by Akentut
Simple fix for the CRC Mismatch Detected. Per their info. Just go to Tools/Firmware Configuration - open the Communications tab, then uncheck "Wait for startup command". Worked for me!
Posted: Thu Feb 22, 2018 12:15 pm
by Damian071
I also own a TRONXY X5S printer and it works good. I did have the issue your speaking of, the way i fixed it and this is weird, I used the lcd screen controls to start the bed heating, then went back to simplify3d tried to connect and it connected fine, since then I have had No CRC mismatch issues. I think the "wait for start command" was disabled when I did that. It was frustrating because Cura, and Reptier did the same thing would not connect. I love using S3D Great software.
Damian
Posted: Tue Jun 05, 2018 7:58 am
by JimmyTime
If it helps, just wanted to add myself as another that was able to solve the problem with unchecking the box in the firmware / communication settings as stated above.
Posted: Tue May 05, 2020 8:30 am
by Austin71
I had the same error. I solved it by inserting an SD card into the slot on my machine.
Hope this helps.
