Chadd wrote:Instead of putting 130% material into the space that 100% would have gone into S3D spreads the extrusion out and in turn will create voids between the extrusion. So it does the exact opposite of what other slicers do.
You're using some odd wording here, so let me clarify things.
I am assuming when you say "130% extrusion" you mean that you have adjusted your first layer WIDTH to be 130%. In that case, yes, the width of your extrusions are increased and thus they will be spread out more. S3D will also extrude more plastic to account for this. If you adjusted the first layer width and it DIDN'T increase the width, this setting wouldn't make any sense (any you'd also probably get a lot of over-extrusion). So first layer width extrudes more plastic so that it can create thicker lines.
Another settings is the first layer height. This will adjust the thickness of your first layer. For example, if you set it to 200%, it will extrude twice as much plastic and create a layer that is twice as thick. This is particularly helpful when printing at fine layer heights such as 0.1mm.
In my mind, both of these settings work exactly as I would expect. If you are needing to extrude a lot more plastic to get a normal layer to fill in properly, then your nozzle is too far away from the build plate. That's probably why you see so many other comments on here talking about the Z-offset or leveling the bed.
