Page 2 of 2
Re: failed to create structure for project file: savedstate.factory
Posted: Wed Sep 20, 2023 11:41 am
by S3D-Jason
Perhaps it's a permissions issue where the software isn't being allowed to save or open that file. If you right-click and choose run as administrator, does the behavior change?
Considering we don't have other customers reporting this problem, it definitely seems like it must be something specific to this one installation. Have you tried installing the software on a different computer to see if the same problem occurs there?
Posted: Wed Sep 20, 2023 11:43 am
by invertmast
S3D-Jason wrote: ↑Wed Sep 20, 2023 11:41 am Perhaps it's a permissions issue where the software isn't being allowed to save or open that file. If you right-click and choose run as administrator, does the behavior change?
I believe the software has always been set to run w/ admin priv, but now that i think of it, this may of started after i updated it to 5.1.2…. I check and report back.
Posted: Wed Sep 20, 2023 1:16 pm
by invertmast
Nope, didn't work opening it as Admin and i dont have a 2nd computer to try the installation on.
Posted: Thu Sep 21, 2023 8:46 am
by S3D-Jason
Another idea might be to look for any Simplify3D files in this directory:
C:\Users\%USERNAME%\AppData\Local\Temp
Usually those are deleted by Windows automatically, but maybe they aren't on your system for some reason. In particular, look for a savedState.factory file or maybe a savedState folder to delete.
Posted: Fri Sep 22, 2023 6:22 am
by Ciurno
I have the same problem, already with the 5.1.1 version.
I was hoping that the update to 5.1.2 would solve the problem, but no.
Posted: Fri Sep 22, 2023 9:22 am
by invertmast
S3D-Jason wrote: ↑Thu Sep 21, 2023 8:46 am Another idea might be to look for any Simplify3D files in this directory:
That did the trick!
Thank you!
Posted: Mon Sep 25, 2023 9:57 am
by S3D-Jason
Ciurno wrote: ↑Fri Sep 22, 2023 6:22 am I have the same problem, already with the 5.1.1 version.
Try following the steps I posted above, as the author confirm that worked for them. Browse to the following folder:
Then delete the savedState.factory file or the stavedState folder.
If that doesn't work, then follow the instructions here to try a complete reset:
https://www.simplify3d.com/resources/faq/#quest-6350
