Re: Pause at z pos
Posted: Tue Apr 28, 2015 7:46 pm
No, the M226 code doesn't work on the DaVinci 1.0. Here's a few lines of gcode I used to pause the printer at a desired layer and then move the extruder out of the way. It stays out of the way for about 50 seconds. If you need more time you can play around with the F value. (Feedrate)
Place this at the beginning of the layer you want the printer to pause at. The gcode file will return the extruder to the correct place and speed. Note that pressing the printers' pause button doesn't seem to pause it while it is doing the following code. I don't know why but it doesn't matter, for me anyways.
;-------------------------------- simulated DaVinci pause / dance ------------------------
;move extruder out of way and then pause by slowly moving the extruder back and forth (PWB)
G1 X100 Y0 Z5
; slow the motors down
G1 F192
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X100 Y0 Z5
G1 F192
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
G1 X90 Y0
G1 X110 Y0
