when you select Print from SD Card, the SD Card must be in your printer. The only time you want to use the G-Code Library included with s3d is with gcode files saved on the hard drive not the SD card.Nofear202 wrote:Ok I did what you said I left the SD card in my computer. Then I went to simplify3D controls and selected print from SD card. Nothing pops up?
Thanks
