jimc wrote:petg tend to be a little stringy. prints will usually have alot of micro fine hairs. this can be normal. all you do is blow the part with a heat gun or run a lighter or flame quickly over the part and they disappear. i dont notice too many thing really over the top with your profile. if your filament dia is correct then your multiplier seems a bit high but that can vary printer to printer. mine is at 98. i assume you have run a thin wall calibration to dial that multiplier in? if your overextruding that will increase the stringing from the extra psi in the nozzle. 255 is ok for the temp but try dropping that to 245 and see what that does for you. again that can vary from printer to printer as well. i never used a bowden so i cant really comment on your retraction but overall it should be similar settings to your abs profile. couple of other things is your speeds seem a little odd. print speed can be up toward the 3600-3800 range. xy movement speed could be a little snappier as well. 9000-12000 maybe. these speed will vary also from printer to printer but yours just seem extremely low. the other thing is those first layer settings. man for a .2mm height those are pretty extreme. i could easily see if you increase your speed that you will never be able to extrude that amount of material without stripping the filament or jamming the extruder. at a .2mm layer height there is no reason to have that higher than 100%. the width maybe 100-125% or so. if that width is greater than the little flat spot on the tip of the nozzle you are just going to make a mess. a first layer like that is completely unnecessary.
Thank you, I will try your changes out. This might be why I am running into skipping issues with the extruder since it can't feed the filament fast enough.
