rrdavis
Re: Modify printer model
Works fine for me in version 4.0. So if you're having trouble, you probably aren't doing something right or you have other profiles that are still overriding the printer model (for example, 1 process that loads the right one, but a second process that isn't setup correctly).
For troubleshooting, make sure you only have 1 process in the list and then just work on editing that profile following the instructions above.
