Rebekah_harper
Re: Problem with dual extruders
from one of my own prints, on a single extruder you can see this between features
G1 X-80.743 Y7.212 E0.0110
G1 E-10.0000 F1200 (retraction)
; outer perimeter
G1 X-80.754 Y-7.228 F4200
G1 E9.0000 F1200 (purge)
but you don't see it on the dual. ???? why is this? surely there should be something
Rebekah_harper
have you tried it without grouping the process' ?
Trax
Without grouping it does not work at all it does not even show the pilar in the preview.
Rebekah_harper
I'll have another look but I am sure that everything was there when I did it.
Trax
Could someone who has a makerbot 1 or clone (ctc/flashforge/wanhao) please post a factory file of a 1 extruders part that he actually successfully printed with such a printer?
Their stock profile is working fine for me. Just select "right extruder only" or "left extruder only" from the extruder auto-configure drop down
Trax
The problem is with the "booth extruders" profile, only left and only right work great.
Just tried a print with the stock "both extruders" profile and it also worked okay. Did you make modifications to the stock settings?
Trax
I started changing things after it failed. Could you post your factory file so I can try something that supposedly worked ok?
I'm literally just using their stock settings. Maybe you should go to help --> configuration assistant again to reload the profiles. I haven't changed anything else.
