Page 2 of 3
Re: Problem with dual extruders
Posted: Mon Jul 06, 2015 2:54 pm
by Rebekah_harper
from one of my own prints, on a single extruder you can see this between features
G1 X-80.743 Y7.212 E0.0110
G1 E-10.0000 F1200 (retraction)
; outer perimeter
G1 X-80.754 Y-7.228 F4200
G1 E9.0000 F1200 (purge)
but you don't see it on the dual. ???? why is this? surely there should be something
Posted: Mon Jul 06, 2015 3:15 pm
by Rebekah_harper
have you tried it without grouping the process' ?
Posted: Tue Jul 07, 2015 6:12 am
by Trax
Without grouping it does not work at all it does not even show the pilar in the preview.
Posted: Tue Jul 07, 2015 11:08 am
by Rebekah_harper
I'll have another look but I am sure that everything was there when I did it.
Posted: Tue Jul 07, 2015 12:31 pm
by Trax
Could someone who has a makerbot 1 or clone (ctc/flashforge/wanhao) please post a factory file of a 1 extruders part that he actually successfully printed with such a printer?
Posted: Tue Jul 07, 2015 6:19 pm
by JoeJ
Their stock profile is working fine for me. Just select "right extruder only" or "left extruder only" from the extruder auto-configure drop down
Posted: Wed Jul 08, 2015 2:22 am
by Trax
The problem is with the "booth extruders" profile, only left and only right work great.
Posted: Wed Jul 08, 2015 6:04 am
by JoeJ
Just tried a print with the stock "both extruders" profile and it also worked okay. Did you make modifications to the stock settings?
Posted: Wed Jul 08, 2015 9:01 am
by Trax
I started changing things after it failed. Could you post your factory file so I can try something that supposedly worked ok?
Posted: Wed Jul 08, 2015 9:32 am
by JoeJ
I'm literally just using their stock settings. Maybe you should go to help --> configuration assistant again to reload the profiles. I haven't changed anything else.
