Re: Deleted some parts when slicing
Posted: Thu Oct 08, 2015 7:03 am
Thanks CompoundCarl! It helps a lot. For me, as a new Simplify3D user, explanations like that are very valuable.
Simplifying the 3D Experience!
https://forum.simplify3d.com/
dkightley wrote:I'd like to correct this statement...Iceman wrote:......There are some files that are not printable using S3D unless you have a nozzle 0.1mm or less, but the "other" slicers will do the job just fine. .....
"There are some files that are not printable using S3D unless you have a nozzle 0.1mm or less, but the "other" slicers will print something...but not quite the design dimensions."
For any printer driven by any slicer, any parts or areas of parts that should be thinner than one filament width will actually be printed at that one filament width.....so interlocking or fitted parts may not fit!. That is, apart from S3D, which will not print anything oversized!
