Re: Top layer not filling honeycomb pattern
Posted: Wed Oct 21, 2015 3:58 pm
Your factory-files do not contain the same objects as shown first. But ok whenever the layer-high is now 0.18
The case is very flat and the heated bed temperature very high and no cooling.
The 110° are near by the glas-temperature of the material and with only 4 solid bottom-layers the melted plastic has no chance to cool down enough. So the following layers of your honeycomb are sinking down a little bit and the nozzle has no contact to its layer-high when printing the top-layers.
The only 3 honeycomb-layers have near 10 mm width when you give them only 30% and with only 4 top-layers you can not close the honeycomb-holes.
90° for the heated bed is enough. Infill 50 - 70%, extrusion-width max 130 %. Moderate cooling (10 - 50%).
Horst, GER
Horst, GER
