Page 2 of 2
Re: "Only retract when crossing open spaces" doesn't always
Posted: Thu Jan 21, 2016 11:06 am
by pbmax
More data!
It seems this problem only occurs when both "Only retract when crossing open space" AND "Avoid crossing outline for travel movements" are checked. If either is checked or neither are checked, retracts off of that support are okay. But if both are checked then the retracts go wonky as shown above.
I'm going to try one or two of my other objects that have this issue to see if unchecking "Avoid crossing outline for travel movements" and leaving "Only retract when crossing open space" checked will produce similar results.
Posted: Mon Apr 18, 2016 10:18 am
by Zorgonaute84
Exact same issue during dual extrusion process.
If "Only retract when crossing open spaces" is checked, there is no retraction between the prime pillar and the part. So for dual extrusion, you have to uncheck this option. But this occured a lot of useless retraction.
Posted: Fri Jun 30, 2017 10:45 am
by Zorgonaute84
Really hope that this issue from 2015 will be fix on the futur "major release"... Seriously, it's the only update I'm waiting for...
Posted: Thu Jul 27, 2017 8:48 am
by Zorgonaute84
Thanks S3D Team, the issue is finaly fixed in the v4.0 !!!!
Posted: Wed Aug 16, 2017 12:23 pm
by S3D-Jason
As mentioned above, this issue was fixed in Version 4.0. All of the sample files in this thread now slice correctly in version 4.0.0 and include correct retractions between the prime pillar, ooze shield, supports, etc.
Thank you for reporting the issue!
