Page 2 of 2
Re: S3D crash error on startup
Posted: Mon Feb 08, 2016 11:51 pm
by pcman
Ah, OK. The three processes were left over from the registry because you didn't completely clear it the first time. The FFFWindow key that I suggested to delete was just to reset your profiles. So, that's not unexpected.
Try again by running the uninstaller for S3D, then deleting the registry key HKCU/Software/Simplify3D and all its subkeys, then reinstalling. If it crashes again, right click on the Simplify3D key and select export then post the file here and I will take a look.
Posted: Tue Feb 09, 2016 2:40 pm
by pcman
Please disregard the last request. Do not post your entire S3D registry key here as it would include your login credentials.
Posted: Tue Feb 09, 2016 11:58 pm
by singhm29
Hmm dont seem to see anything in the log file about my credentials but ill refrain. Ive been talking to S3D tech support and sent them the log file, hopefully they can resolve it quickly and I can throw up the solution.
Posted: Wed Feb 17, 2016 12:28 am
by singhm29
So turns out the crashes had todo with a fourth monitor I connected that couldn't support the same resolution as my other monitors which caused my video card togo a bit wonky. I ended up switching out the monitor to one that could be consistent with the others and reinstalled. All is good!
Thanks for the input!
Re: [ Solved ] Windows 10 S3D crash error on startup
Posted: Wed Feb 17, 2016 5:22 pm
by pcman
Thanks for completing the thread. It might help someone else in future. Of course, I never would have guessed you were using four monitors! I use 3x27" @ 1920x1200 without problems but S3D is only ever on one and I sometimes have the control panel on another. It seems odd that yours would work when the registry entries were deleted though.
Re: [Solved] Windows 10 S3D crash error on startup
Posted: Mon Jul 17, 2017 12:00 am
by Javanator
Thank you! I'd like to add my experience: I have 2 3840x2160 monitors and had this exact same issue. Support was unable to solve it. After reading this thread, I tried disabling one monitor, and it worked! Now I am asking support if they can reproduce this and fix it.
