Page 2 of 2
Re: my object is hollow?
Posted: Fri Feb 26, 2016 2:09 am
by NoHands
bloody hell im gonna try get a refund on the model
Posted: Fri Feb 26, 2016 11:59 pm
by airlid
There is a hole in the bottom of the model so it is actually a shell. For a 3d model to be considered a "solid" it must fully enclose a volume of space. Fill the hole then "repair" and it will become a solid and print with infill.
Tried it, Done it, it worked :-)
Larry
Posted: Sat Feb 27, 2016 12:21 am
by NoHands
Thankyou heaps Larry
i contacted the designer and he fixed it but gd to know for next time :)
Posted: Sat Feb 27, 2016 1:53 am
by horst.w
Hi Larry,
You could open the factory-file?
Normally a hollow object doesn't makes difficults when there is a outer-wall and an inner-wall (like a cup or glass) Then the outside and the inside together represent the enclosed solid body. If it is not so, S3D opens nevertheless - ok, it is not ready to print, but it opens!
However that is the first time, I couldn't open a faulty file like this.
@ Nohands
Have a look to this site:
https://netfabb.azurewebsites.net/
there you can repair your STL for free, it works very fine!
Greetings
horst, GER
Posted: Sat Feb 27, 2016 2:30 am
by NoHands
cheers Hort i'll look into netfab
NoHands, Aus
www.higherthansuperman.com
Posted: Sat Feb 27, 2016 10:27 am
by airlid
horst.w wrote:Hi Larry,
@ Nohands
Greetings
horst, GER
It opened just fine for me. When I sliced it, it was hollow with inner and outer shells just like a crystal goblet. It printed that way as well. I was tempted to let it run to see how far it could go ( the print) but I could see that it was not going to work.
I plugged the hole with 3D Builder (microsoft) and then the model sliced as a solid with infill.
Larry
Posted: Sat Feb 27, 2016 6:28 pm
by NoHands
I printed it with 20% infill and it turned out brilliant just gotta smooth it now
