dorsai3d wrote:If you look at your gif, the only spot you'll have meaningful layer adhesion is where those corners lay on top of one another, and the rest will barely adhere since it's only printed every other layer and offset from the previous line. Hence why in the link above, 3D honeycomb is nearly the weakest of all tested in both orientations, and grid infill (both rectilinear angles on each layer) is stronger than any that are listed in that post.
Thank you both for the conversation...CompoundCarl wrote:dorsai3d explained it quite well. The 3D honeycomb pattern is quite weak compared to everything else, so I for one would rather have the developers spend their time on something else. It's actually quite easy to calculate why the pattern is going to be weak if you took a mechanics of materials class. You are FAR better off using grid or triangle if you want maximum strength. I have printed dozens of test specimens now that also confirm this. So this pattern is NOT stronger, in fact it is much weaker than the other patterns.
The grid and triangle patterns were actually already stronger for sideways loading, but if you want even more strength, try adding a few diaphragm layers. That will create solid layers every 20 or so layers which also adds even more strength.
While I also love crazy infill patterns, they will not be visible in all practical cases. And I believe that the purpose of the software (S3D) is to make infill practical, and leave the artistic side up to the design software. On a FDM printer the strongest patterns are triangular for allround, and grid for top/bottom. The weakness with 3d honeycomb will be in the layers. Because they are the weakest link so the structure will collapse when energy is enough, But when you print 90º on top of the layer below, the bonding strength is at maximum and hence the strongest structure. I typically print triangular infill but skewed about 22º, so that for most objects a right-on hit will disperse the energy throughout the model.ReneeCelDesigns wrote: I would love to see loads of new and wacky infill patters... some Structural ones and some mad ones!
+1 to more infill patterns. I like to print things with 0 perimeters or 0 top and bottom to get interesting effects.AreDigg wrote:While I also love crazy infill patterns, they will not be visible in all practical cases. And I believe that the purpose of the software (S3D) is to make infill practical, and leave the artistic side up to the design software. On a FDM printer the strongest patterns are triangular for allround, and grid for top/bottom. The weakness with 3d honeycomb will be in the layers. Because they are the weakest link so the structure will collapse when energy is enough, But when you print 90º on top of the layer below, the bonding strength is at maximum and hence the strongest structure. I typically print triangular infill but skewed about 22º, so that for most objects a right-on hit will disperse the energy throughout the model.ReneeCelDesigns wrote: I would love to see loads of new and wacky infill patters... some Structural ones and some mad ones!
