Re: 3D Honeycomb Infill
Posted: Tue Jul 05, 2016 3:34 pm
If you look at your gif, the only spot you'll have meaningful layer adhesion is where those corners lay on top of one another, and the rest will barely adhere since it's only printed every other layer and offset from the previous line. Hence why in the link above, 3D honeycomb is nearly the weakest of all tested in both orientations, and grid infill (both rectilinear angles on each layer) is stronger than any that are listed in that post.
