Re: solution to show estimaed print time needed with cubicon
Posted: Sat Dec 17, 2016 9:05 pm
When you compare the gcodes from both software, you can see a few mcode commands in the beginning of the gcode..Martin3d wrote:
if anyone how how to find the print time, here are both HVS files from cubicreator and simplify3d:
https://www.dropbox.com/sh/9n0m5je1c0ci ... kgX9a?dl=0
gcode compare find print time in gcode
cheers,
Martin
M910 S793
M914 S250000
M915 S121449
914 is the Baud rate, Maybe one of the other 2 commands is responsible for sending the build estimate data to the firmware. Try including that in the S3D gcode and see if that displays the build time on the LCD
