Re: Removed Supports still being generated and printed
Posted: Sun Jul 10, 2016 8:02 am
Ah now I understand; So S3D doesn't distinguish (record) between removing all existing support with a model that has not had any existing support. I think the reason why I've never seen this behavior before is that I don't think I've ever had 2 models, where one didn't need any support while the other did on the same print session, using one process.andrewk72 wrote:To be clear, there is a different between "I removed some supports" and "I removed all of the supports for my entire model". As it says, if you enable support generation, it's going to make sure that there is SOME support for the model. The only way to stop that is to either add your own supports manually or disable support generation all together. So if you are trying to stop support from being added, then just disable support generation.
If you're still having trouble, post your factory file and explain exactly what steps you are taking.
For the sake of my sanity, please show me in the above mentioned tutorial that "As it says, if you enable support generation, it's going to make sure that there is SOME support for the model.". is located, because I can't find it anywhere, so I must be missing it.
Thanks for your help.
