Page 2 of 2
Re: 20mm calibration cube issues
Posted: Sat Oct 15, 2016 5:51 pm
by LazyWolfe
dorsai3d wrote:Okay. Sometimes it's the obvious, sometimes not. Best bet would be to reload the Creator Pro profile from the config assistant (Help menu), then compare skeinforge settings and Simplify3D settings.
I've done all that as well. But Skeinforge offers settings for only a small fraction of the variables that S3D provides for. e.g, just to change heated bed temp requires that I edit the gcode. It's only by guess and by golly that I've located the line of gcode that sets that temp. My current effort is to figure out what the gcode is really doing so I can try to connect the dots betweeen REp3 and S3D.
I do thank you for your continued interest.
Lazywolfe
Posted: Mon Oct 17, 2016 8:38 am
by wirlybird
Here is a long shot but it just happened to me. Check that the bed temp is what it says it is. I have a printer that was making bad prints and when the print would finish it was like rubber for a bit. Finally figured out that the bed was heating 30-40c higher than it was reading.
Posted: Tue Oct 18, 2016 4:08 am
by mertseger
Hi.
Not to open another topic I will ask here. I m totaly new in 3D printing just print first calibration cube. Have issue with temperature but I fix that. T print cube 15x10x10mm. Cube looks nice but dimensions are far away 15,67x10,15x10,13mm. I have Malyal M180 0,4 nozzle and PLA. what should I change in settings to get better resoults.
Thanks!
