Page 2 of 2
Re: Seam/Z-scarring significantly better in Silc3r - Setting
Posted: Mon Dec 05, 2016 4:37 pm
by Malakian
Z axis movment/travle speed to match X/Y travle speed.
My Z travle was 16.7mm/s, while x/y was 80mm/s in S3D.
Slic3r uses the same setting for X, Y and Z. That was the difference.
Posted: Tue Dec 06, 2016 8:46 am
by Malakian
Slight update. After I got the seam test good, I did a benchy. And there was still some blobs/divots though a lot better. Ticking off Update Machine Definition and Update Firmware Configuration made it more similar to Slic3r's seams benchy. Seems like S3D is doing something my printer doesn't agree with, so now it's running completely off Firmware values. Well, except Retraction settings, you need to Force the slicer to use Firmware retractions, but I don't even know where those settings are in Marlin so I leave that off.
If you want to try that route, you have to be sure your firmware values are correct. Like bed size etc. Or bad things will happen.
Posted: Tue Dec 06, 2016 11:39 am
by wirlybird
You mention Marlin - what printer?
Posted: Wed Dec 07, 2016 6:25 am
by Malakian
It's a heavily upgraded Rigidbot Regular, single extruder.
Posted: Thu May 04, 2017 3:01 pm
by mrehmus
I am having the same problem. A line of sharp-edged blobs up the O.D. of a cylinder. The straight cylinder has a thick part at the bottom of 3/8" wall thickness and the O.D. in that portion is OK. But as soon as it transitions to a 1/9" wall thickness, the blobs appear and extend up the 2" height. Actually it places lines of blobs in two places on the O.D.
I tried the same STL file in Cura and it prints with no problems.
I cannot remember that I've upgraded S3D so I don't know where these problems have come from in what was a great product.
I can print a calibration cube generated through S3D and it prints perfectly.
Printer is a Qidi X-one, a very reliable printer.
