Page 2 of 5
Re: Wipe While Retracting...
Posted: Tue May 13, 2014 5:38 am
by glx51mm
Can someone verify if this issue has been addressed in 2.1.0 ?
Posted: Tue May 13, 2014 11:17 pm
by laird
+1. Nice find!
Posted: Wed May 21, 2014 9:29 pm
by jwiede
+0.7
Posted: Mon Jun 09, 2014 7:30 am
by theray
Got the same problem with a Rostock Max v2. I found the same workaround works but i can't change all the retractions by hand so i had to make a little gcode translator for modifing these lines... I would like to see a check box on the print settings that allow to choose the standard retraction system or the one explained here. Rectraction and next move merged in the same line.
Posted: Mon Jun 09, 2014 3:20 pm
by stevedev
+1
Posted: Mon Jun 09, 2014 7:24 pm
by neobobkrause
+1
Posted: Fri Jul 04, 2014 12:24 pm
by prcdslnc13
Did this ever get fixed? Im still having similar issues in 2.1.1
Posted: Mon Jul 07, 2014 2:55 am
by HBWray
+1
Please fix this I am having issues with this is 2.1.1 as well.
Posted: Mon Jul 07, 2014 3:02 am
by vOidward
prcdslnc13 wrote:Did this ever get fixed? Im still having similar issues in 2.1.1
Nope, still pauses before a wipe in 2.1.1
Posted: Mon Aug 11, 2014 5:04 pm
by thews
Can you post your script to modify the gcode?
theray wrote:Got the same problem with a Rostock Max v2. I found the same workaround works but i can't change all the retractions by hand so i had to make a little gcode translator for modifing these lines... I would like to see a check box on the print settings that allow to choose the standard retraction system or the one explained here. Rectraction and next move merged in the same line.
