Re: Factory file vs process exporting?
Posted: Mon May 22, 2017 7:50 pm
You CAN export a profile to a file, you can also save every project to a factory file. There is nothing you cannot save to a file.
Simplifying the 3D Experience!
https://forum.simplify3d.com/
That is a workflow/quality issue. Who ever on the production floor that finds a flaw should track down and delete any "non conforming" files, or otherwise isolate them so they aren't used. The flaw is fixed then updated files posted to production. In an ISO shop that is actually a procedure to follow.msaine wrote:You totally miss the point. S3D is one of the pay for slicers, one would assume it is designed for a production environment. In a production environment you need control over processes to be repeatable. People are careless, that is one of the reasons computers are so great, they don't forget. Imagine you are building a part that takes 12 Hours to print and you discover a flaw that requires a different setting in the setup. You fix it and save a new process and or factory file and all is great. Then another member of the development team goes to print the part again and neglects (or is not told) to load the updated factory file. Bingo you have another bad part and it's 12 hours later on a short schedule. All because the software cannot be set to load the latest files from a production repository.
Now do you understand the real problem? Yes you can save files but you cannot rely on the power of computers to automatically load the correct parameters because the current software doesn't do it. People are sloppy and will forget!
Can you really expect the software to predict what you are wanting to do? If there might be a need to use something again...then SAVE it! And its really isn't difficult to save a copy .....and it's everything you need to be able to go back to.....as a factory file...... (did not save it as a factory file) ....
