Page 2 of 2
Re: Graphics bug with HI-Res/4K monitor
Posted: Wed Jul 26, 2017 2:44 pm
by Barafu
How could any hardware be a culprit if the screen worked normally in S3D 3.1 1 ?
Posted: Wed Jul 26, 2017 3:14 pm
by wirlybird
Also on your Win10 machine look at display scaling. This may help. Once you get around or past a resolution of about 2560×1600 then the standard 1:1 scale can get way to small on a 4K monitor.
Settings>System>Display and adjust the slider. Might help.
Another thing to try which can be an issue is running multiple monitors with differing display resolutions.
Does S3D display the same behaviour on the 4k if it is the only monitor?
Posted: Wed Jul 26, 2017 3:52 pm
by Enginwiz
Scaling problems with S3D 4.0.0
Windows 10 64bit - Dell Precision 7710 - Nvidia Quadro K5000m - Dell ISV CAD driver
Internal display: 4k running as 1920 x 1200 UWXGA: Everything OK
External display: 4K running native als 3840 x 2160: croped menues, missing texts, unusable
Simplify3D 3.1.1 runs flawlessly on both displays.
This needs to be fixed.
Posted: Wed Jul 26, 2017 11:03 pm
by upsm
it is not a hw problem, if the problem was that hdmi is not fast enough for that amount of pixels (it is not, that's why you have to run 30hz, upgrading to displayport will probbly give you 50-60hz on the same screen) there would not be an image on the screen, but since there is an image on the screen it has nothing to do with drivers &| cables &| connectors but with software bug
Posted: Thu Jul 27, 2017 10:58 pm
by rhbruning
I have the exact same problem with my K2100M NVIDA graphics card in 4K mode. I have an HP zbook G2 15. Some of the symptoms are windows within windows, windows smear when moving, parts drop in at funny angles and the center of view rotation/zooming moves outside the view window. This is often remedied by resizing my window in any way. It sounds like this happens on two or more different graphics cards.
Posted: Fri Jul 28, 2017 12:50 pm
by bbinnard
Yes, I should have said that my old 3.1 version did run fine on my 4K monitor with exactly the same graphics settings that now produce the problem I showed in the first post.
So is it generally agreed that this is a software bug in 4.0? It seems pretty clear to me that it is.
Posted: Fri Sep 29, 2017 2:39 pm
by bbinnard
I just discovered a simple fix for this problem:
Right-click the Simplify3D.exe program file and select Properties/Compatibility. Then check the box "Override high DPI scaling behavior" and accept the System option for Scaling performed by. Then click OK to make the change.
Posted: Tue Oct 03, 2017 4:59 am
by Enginwiz
The simple solution "Override high DPI scaling behavior"
doesn't seem to work on Windows 10 x64 Version 1607.
The menues and some texts are still clipped.
Posted: Tue Oct 03, 2017 10:58 am
by bbinnard
Very interesting - my version is Win10/64 Home Ver. 1703 Build 15063.608. This is the Fall Creators Update (whatever that means.) You should be able to get it by using Windows Update. It installed fine for me.
PS: I don't know if it matters, but I have an nVidia graphics card driving my 2 monitors.
