Re: [Bug] When changing layers, the Z step should be first
Posted: Sun Jan 14, 2018 6:31 pm
Thank you. You have explained things very well, and confirmed my thoughts on all of these settings. I was confused by people that were telling me retraction affected the Z-position of the print head. Pure retraction doesn't appear to do that, but the Retraction Vertical Lift does provide the capability for this Z-axis motion. I appreciate the education on this.dkightley wrote:I'll have a go at explaining these settings for you....
1) Retreaction - this is reversing the feed of the filament in order to reduce the pressure behind the nozzle...and is the distance by which the filament is retracted.
2) Extra Restart Distance - the above setting winds the filament back by the specified amount....and then forward again by the same amount so that printing can progress. The Extra Restart Distance is an extra distance the filament is fed forward again. So Retraction of 5mm and Extra Restart Distance of 1mm will result in the filament winding back 5mm...and then forward by 6mm.
3) Retraction Vertical Lift - is separate to Retraction....and is the distance by which the whole print head is lifted upwards ( or the bed downwards) before an X/Y move is made. This is to prevent the nozzle dragging on the printed plastic.
4) The speed at which 1) and 2) take place.
5)Coasting Distance - this is the distance in advance of the end of an extruded layer when the filament stops driving plastic through the nozzle. In other words, a distance to allow for the flow of plastic to exhaust the pressure and come to a theoretical halt.
6) Wipe Distance - exactly as it says, this the distance the nozzle will wipe across the top of the just printed layer after the layer has been completed. This then wipes any excess plastic onto a surface that will subsequently have another layer put on it.
Hope this helps.....
Based on your apparent knowledge of these settings, what do you think about my original contention that S3D is performing the x-, y-, and z-axis motions in the wrong order when changing to the next layer?
Mark
